How to aim fog lights (07 Speed 3 GT)???
MM BOOST
07 MS3 GT CB
Hey guys, I just recently had my fog lights independently wired up and I have a new set of HIDs installed, but one of the fog lights seems to be aimed lower than the other. I am planning on removing the reflector shield this week, but I would also like to figure out how to aim the fog lights. Does anyone know how to do this or know of a how-to anywhere with a link? I was under there messing around yesterday and found a screw below the foglight that looked like an adjustment screw, but when I loosened it, nothing happened. Can anyone help me out? I would greatly appreciate it!
i don't know if we could aim it up b/c it just screw on only to the bumper..!! or could it?
there is a screw/nut at the bottom of the fog light. There is a thread somewhere. you loosen it and manually push the fog light around to adjust it I believe... If I find the thread I'll link it.
I'm not sure that there is adjustment in the fog light. But it should not take movement in it to adjust it that you could get by losing the screws and try holding it in the position you want and screw it back down.
I figured it out. There is a screw on the outside of the fog light closest to the grill, and then you loosen the locking nut underneath, and the whole fog light swivels in the perch. I got my fog lights fixed now, thank God.
