SpeedBeaver
- Mazdaspeed Protege
Admins and Moderators, please feel free to move this how-to to the proper section since I can't post in it.
This is a translation I did from the original "How-to" written by SoundTest on www.mazdatuning.com
It was his idea, and his idea alone, I do not take any credit for this how-to. I only translated it.
Original How-to by SoundTest
For the "Nay sayers" please refer to the following scan taken from Corky Bell's "Maximum boost" book.
Here is how to turn up the boost on your MazdaspeedProtege by using a carburator spring. You don't even need to jack the car up. You'll need a ratchet with a 10mm socket, long nose pliers, and a carburator spring (part #24-5582-8 at canadian tire / Prt # 59002 from Autozone- You need to curve both ends to make hooks so you can install it properly). You use the biggest one in the pack. Mechanics gloves (in case the mainfold is still hot)
Ok, you must first visualise what needs to be done, mainly where the spring must be installed. On this picture you can see 3 color circles. The red one shows the wastegate's actuator, the green one the wastegate control arm, and finaly the blue one is showing the wastegate's valve command. When the boost is rising, a pressure is created in the actuator, the actuator then pushes the control arm to open the wastegate's valve. By installing a spring between the valve and the actuator itself, you increase the pressure needed to open the valve. This is due to the tension the springs put between these two points. Different springs could be used. The I recommand using is a 2lbs one so that the boost wil be raised to 8lbs or 8.5lbs depending on your stock boost level.
First, remove the exhaust mainfold heatshield so you can see and access the actuator's control arm.
Here you can see the control arm between the intercooler's piping and a radiator hose. (yeah, that picture is crappy I know...)
here you can see the actuator, the spring will be attached to that goldish metal peice protecting it.
Here you see how to hold the spring with the long nose pliers so you can install it.
If you got big hands, you should consider removing the intercooler's hot-pipe (the pipe between the IC's top and the turbo), so that you'll have enough space to work. With your right hand, hold the spring with the pliers and you guide it with your left hand (here the guy putted a glove to avoid burning himself on the mainfold).
It takes lots of patience to be able to get the first end of the spring hooked up to the wastegate's valve that you can't actualy see. That's the reason why you must know what you're looking for (blue circle on the 2nd picure from the top)
Lots of patience....
Once the spring is hooked correctly on the wastegate's valve, you must stretch it to hook the second half to the actuator's goldish protecting metal peice.
Then you only have to bolt back the mainfold's heatshield and the intercooler's piping (if removed. Be sure not to forget anything in the engine bay! (glasses, tools, anything you could have forgot in the engine bay cuz at this point you must have used about all the patience you actualy can have in a whole day
). Take it for a spin! Depending on the spring used (tension specs -> lbs) you can get 2psi verry easily! Have fun.
SoundTest
Translated from French by SpeedBeaver
SoundTest
