How long do you let it drain? I try to leave it for 30 - 60 minutes. Putting the front tires on boards or something will speed up the draining. I get the full amount out. (5qts)
that sounds about right, there are a bunch of oil galleys where the oil can hide so .2Q's doesnt sound like much
do you warm up your engine before changing the oil?
5 Qts after about 10-15 mins. I did the 5 Qt Jug and 1 Qt bottle and ended up using the Jug only. Checked it after 2 weeks and level was still good. I did the Penzoil Platinum which had a $15 rebate so that Jug was only $4.99. I just need to stock up when there is another rebate.
