There shouldn't be any exhaust leaks at the turbo. You also shouldn't use any gaskets on the turbo-manifold or turbo-downpipe joints either, as they blow out and leak.
Keith
I didn't vote, but here's my problem....
The CEL will come on occasionally, and stay on for about a day(100 miles roughly). When it shuts off, it stays off for weeks at a time. I haven't bothered pulling it out yet to check for a loos wire, but I might this weekend. It's on right now now that I think about it. Oh, it's the one from Apex if it makes a difference.
Keith@FP said:While the manifold has probably not warped, it's possible that you don't have a flat flange due to a manufacturing defect. If you've got access to a belt sander you can use that to check.
Keith
Hello Chaz, do you have a .63 exhaust housing?
I see no problem with how the manifold is made, it is very good casting. If it is over tighten or if your exhaust temp get real high you can warpe it. Again this has nothing to do with how the manifold is made, I have used it and it is a very good manifold. I think for most people it would work better then a turbo header. Was it a new unit or the old one?
Thanks again
IIRC, this is one of our manifolds we're talking about.
The flange mounting surfaces are machined after casting. If the machining is not done correctly, you can get a leak. Warping isn't really a problem with them, the manifolds are very stable. No matter what the cause, it's a good idea to check your flanges are flat.
Keith
