How long to run AC to see the drips under the car
CX-5, fwd auto
HI,
I think my drain plug is plugged. Can anyone tell me how long I need to run AC on my car before seeing the water drips from the bottom of my car?
Also I have an idea of general drain hose location. If it is plugged, how do I fix this problem. Please advise.
Thank you
How long to run? That all depends on the ambient temperature. In hot weather it should take a shorter amount of time than cooler weather, as condensation will build up quicker. I have not personally worked on a CX-5's A/C system, but all vehicles I have worked on has the drain (not a plug, but a hose) on the passenger firewall. Once you find it, an unbent clothes hanger poked into it should clear it.
