How does the AP stg1+ mscai work??
MS3Zoom24
2008.5 Mazdaspeed 3 Metro Grey Mica
(so this is regards to how well does it work with the AEM+ ets tmic+ hks ssqv???
Does anyone have similar mods to shine upon me with insight???
IM looking to get this soon and just wanted to know how well or not it works and how much ATR would be needed
Thanks for your help(drive2)
no one can answer that, even with the correct mods for a map the results are spotty. Count on using ATR, if you want the ap.
yeah that is what i have been reading especial yoiu fjames, and other over at msf.
How much will I have to use ATR, to reall get a good working map??
I know that i will have to do the MAF calibration, jerky throtle response, and other fine tuning.
There is no way to tell until you get some logs. Its not that hard man we will walk you through it on the other forum
Dread, would you say the AP is worth getting???, Im just worried that im going to get it and for some reason it is not going to be worth it and then sell it like i see people do now and then.
Probably just being paranoid, but it is $700.
I have had it since the day it came out and while I originally started to regret my purchase due to the bad original maps, the new maps and release of ATR make it the best tuning solution available and I couldn't be more satisfied. You will notice a big improvement in how the car drives. Power increases under the curve are significant and with ATR my car is running like a champ. ATR takes some getting used to, but is relatively easy to use once you get the hang of it. Get the ap and you won't be disappointed. If you need to tweak the map to get it to run correctly we can help you out on the other forum.
