I asked him about it again, and I remembered wrong. I think the speed he actually had it up to was in the 125-130 range, sewhat more than what my stock s touring did anyway.
the vsg on all us mazda 3's is 188.00 kph or 116.86 mph
Nope the ground speed limiter has no input from the rear wheels. On the abs cars it takes the input from the acu, on the non abs it comes from the ring gear in the transmission.
The only way to remove the limiter is to rewrite the bin file for the GS map. Hypertech claims thier new flasher can do it, but only 10-12 kph increase.
Piasini is the only way to remove it all the way
Disconnect the VSS - then the ECU will not know the vehicle speed - voila!
No, I have no need to bypass it, I was just offering a suggestion.Have you done this yourself on a 2007-2009 Mazda 3?
