Hopefully someone can help me out here
rmbmazda
06 Mazda 5
I just bought 18*8 Bolt pattern: 5*114.3 offset:+45 for my mazda 5 and planning to buy tires. Is it possible to put 235/40/18 instead of the regular 225/40/18?
you might want to test fit your rims 1st. mazda rx-8 are 18x8 50 offset and stick out just a bit on the front. the rims you have may stick out 6mm or so.... 235 will work if you want the fat tire look....
