RockBlocker
Hood Damper Kit Polish - 05+ Mazda 6 - Product Description: Often times, injury while working on a vehicle is caused by the hood falling on an individual. This product is offered for that purpose as well as a way to exhibit your under hood modifications. This unit allows the hood to remain up and stable even under high wind conditions. Thoroughly tested for repeated use, they are made with the highest quality aluminum case and steel shaft. Weighs in at only 200g on average, this is a must-have addition to any hood prop vehicle. Product Features: Features: Easy to install and all hardware included. 2 Types aviailable, one for lightweight hoods, and another for standard hoods. Please specify when ordering. Hydraulic damper assembly: oil filled shock light dampening formetal hood applications lift assist and slow decline features. Material: Stainless steel w/ lightweight alloy shaft and casing with hydraulic oil seals end links for mounting points for durability and heat resistance.
$199.99 REDUCED to $95.00 in Silver Shipped Right now
$249.99 REDUCED to $135.00 in Carbon Fiber Shipped Right now
To Order
To Order
