Not that I know of...and you didn't say anything faulty...
I was just pointing out that its the advanced timing that is giving the power in the Mp3 ecu...not that the higher octane rated fuel is giving more power...the higher test only allows the advanced timing, if you know what I mean...
but no...the ecu wouldn't know what to do with race fuel...the physical aspects of the engine are not designed to run on that stable of a fuel...and there is a point with ignition advancement where it simply hurts power, even if there is no detonation occuring...a common issue with F1 engines...the MP3 ecu will reach its full advancement with normal premium gasoline...I would bet that with a much higher octane rated racing gasoline, the engine would actually be down on power because of the fuels stability and buffer properties (again, race gas is designed to be extremely stable because it is used in extremely hot and extremely compressed racing engine environments...not in a more or less stock FS)...I don't know for sure, but I am nearly positive you will not gain hp by using 105 octane gas...aside from other additives that may be in "off road" mixed gasolines...(that is where I can't be positive, because different race gas has different other stuff in it to help power anyway...its not street approved, so they do not have to go through all kinds of hoops to make it environmently friendly...because of that, my point could get skewed)
