Hks turbo timer install questions
I have a couple quick questions...
1. In the hks manual it says if i dont install the ebrake sensor wire, the turbo timer will not work. Is this true or is it a safety plea?
2. I'm going to take a picture of the turbo timer's wires and hopefully you guys can tell me what they're for.
the wire u need to splice into the ebrake wire is the gray and orange dashed one
also u cant use that connector on those wires, u have to cut it off and use wires and slpice into the ignition wires
which wires go to what on the ignition idk cuz i cant even get mine to work right lol
edt: yes its true, if u do not hook up the e brake wire it will not work, the car will just shut off
