RE: Yellospeed
My kit is a dual-beam kit... For sure, the cable is not very long, that is as far as the cable will go leading to the passenger side ballst... I have no other location to mount the ballast...
I also ran the wire to the passenger side right in front of the intake assembly... The wire is hanging over the intake assembly support bar.... I felt the wire and it is warm like other wires, so I think it is not a problem... BUT NOT SURE....
I try to post a picture later....
RE: Natey
Yike... If you did not warn me, I will not even bother opening the hood to check the tape... That ballast is hanging loooooose...
Why did the ballast got shorted? Isn't the ballast have those protection and water-tight sealed???? I am getting worry...
very worry indeed... I dont want my kit to be plug-and-no-play after a month...
I found my drill can't get thru for a little hole... too crowd...
I'll seeeeee what I can do.... for a more secure installation...
Thanks a million.... thank you
