The going rate around my area (closest I believe is in Harrisburg, PA) is around 100 bucks for 3 pulls, and $150 for 5...so yeah it is sort of pointless unless you are really interested in your gains or need the pulls for tuning purposes...
I have never seen a dyno with your exact mods more or less...I would bet you are around 115whp, that being on the conservative side...You completely cured the single most restrictive part of a P5 (being the down-pipe)...and some guys were gaining as much as 11whp with only a AWR header, while maintaning the secondary cat...the axle back/intake combo should be good for "at least" 4whp I would think...
Assuming you are going with the J-spec cams, expect another 10whp on top of your already 15...the other two mods are more difficult to predict...both lightweight flywheels and pullies help mostly with acceleration and first, and a good bit in second, but by 3rd gear they start to become less noticable...More importantly they will immensely help with a hard pull to redline in first and second, which is excellent for 1/4mile runs...if your tires are in good shape I would bet you could be getting into 15.60-70-80 range...
IMO don't worry about the pullies as much as the flywheel...try getting a custom 60-65mm center pipe to complete your exhuast (do you know what the diameter of the HKS axle back is by the way?), that could free up another 2-3whp for relatively cheaply and with the other mods you will be easily over 130whp...
To put this in perspective on straight line acceleration, a 60lb lighter 02 Spec V, which is crippled by unbeilevably bad breathing above 5 grand and horrible gear ratio's can manage a 1/4 mile time in the 15.20-30 range with a decent driver (and the spec V has a stock whp rating of about 142) yes it has more tourque but don't worry about that, the gearbox does not allow the car to take advantage of it... if you have roughly 135whp, and in this case much better breathing (most of the time in a 1/4 run the engine is boiling...your FS will be much happier in these rpms than the QR25DE?? or whatever the Spec V has) and much better ratio's (still be hitting 62mph in second gear, and have a much shorter 3rd than the spec...)...You will probably clock in around mid 15's or a little above...so yeah the spec v will still be a little faster, but you will have definatley made him sweat a little with a little over a grand in mods....
