HFC?? Worth it,
Understood. I thought you had a straight test pipe behind your catless dp. Clear now. Thanks. Yes, with better flow from the high flow cat, you should see an improvement in responsiveness of the turbo to changes in exhaust flow. I don't know if this is measurable, but even if you do not build boost quicker, you should flow better and that means more power across the entire power band.
