help with timing a 97 626
prosper1ne
mazda 626 1997
97 626 timing problems please help
not sure if this is posted in the right spot or not.
my question is this... where is the spout connector on a 97 626?
does it even exist. i replaced the water pump and timing belt. im pretty confident i put it all back together correctly. problem is, its not in time.
the book says find the spout connector near the battery. but i cant find it. it wont pass smog because its not in time. i can move the distributer all day long but it doesnt make a difference. i think i need to make a jumper to by pass the computer. can someone help me out?
i know this question has been asked before because ive searched the web. problem is nobody has an answer. i also tried to search the forums.
any help would really really be apprecited. thank justin
there should be a diagnostic connector near the driver's side strut towner... flip it open and jumper the TEN and GND pins
i found that and i tried to jumper the 10 pin but its not there! there is no pin 10 as far as i can tell. i even looked under the thing to see if the pin fell through. am i missing something or were there some models with no 10 pin? please help. thanks
Similar Threads and Articles
