Help with suspension!? 2006 MZ3 sedan.
Incdalton
Mazda 3 i touring sedan 2006
Alright so I have a 2006 Mazda3i sedan. 2.0L
I upgraded wheels to Enkei EDR9s. 17x7 I believe.
Basically, what I wanna do is put it on lowering springs, coilovers are a no go for me.
I was looking at the Eibach Extreme lowering springs. They lower 1.7" in front and back. I also want to get some Eibach 10mm spacers. Will I have any problems with this set up? Like, fender roll... Camber. All that? Thanks everyone for the help in advance.
Buy some SPC camber arms, take to alignment shop, have them install for you, they will set the factory camber, youre good to go :)
Not a must, but dam sure wanted. lol I dont wanna go through tires so i bought the camber arms.
So, I won't need a front camber kit? Just two rear camber arms? And what's the best brand to go for? :P
Btw, 5 stars for you. Thanks x)
Our cars have front camber adjustment, well our rears do too, but not enough. The front will get you back to factory, I purchased SPC camber arms, (made by Eibach(i think))
Btw, when you say Eibach Extreme lowering springs, do you mean the Sportlines?
What shocks are you going to get? or are you staying stock?
I believe they are the sportlines. They drop 1.7" all around. And alright thanks :P
But I'm staying stock shocks unless I see fit to upgrade.
How old are your shocks?
My friend has been on sportlines with stock shocks and his ride is fine, but he is going to full coilovers. his is a hatch so it is heavier...
You should be fine!
Ok I have tein s tech I run 2in front and 1.8 in the rear I have little camber you'll be fine unless you run an agressive set up like 18x9 I'm running a 18x8 if your a 17x7 you'll be fine
