Help with Rear Torsion Beam Axle Dimensions
Hello,
Can any of you who already have a Mazda 2 please help me confirm a dimension on your rear torsion beam?
Long story short, I am looking at an off-label use for the DDMWorks sway bar, and I have not been able to get an answer from their tech department on the length of the bar. I need to know the length from center to center to the two mounting holes in the picture below. From what I understand, the lower hole is already drilled out so it should be a simple measurement.
Unfortunately I don't have a Mazda 2 to check, so any help would be very much appreciated.
Thanks,
Shadowfax
