Hi guys,
Experiencing a problem with boost gauges.
I installed a GReddy Profec B and during this time I re-ran all the vac lines with new ones. The Vac line on the Profec is T'd to the FPR and this line is T'd off again to the Autometer Boost Gauge after the Profec B's Filter.
The problem I am having is that once in a while, the car will not read Vaccuum. Both the Profec and Autometer will read 0. If I shut off the car, the gauges will go to -20 hg and then back up to 0. I restart the car and again it will read 0. I drive for a few minutes and the gauges return to normal.
I checked the vac lines for leaks, but none can be found.
Does anyone have any suggestions on what could be wrong?
Thanks
Thanks
