Help Traction control issue!!!!!!
Qu@rtz22
06 Mazdaspeed6
On Wet days recently when giving my speed6 hard throttle over 4000rpms the traction control light comes on and my engine power cuts down almost completely throwing me almost into my windshield. Then engine light comes on. this only happens when its wet and there is definitely no loss of traction that i can see or hear. Is this a sensor problem, has anyone else had this happen. HELP!!!!!!!!!!
Could be a differential problem when teh torque gets split to the rear wheels.
a little bit of engine lug is common when AWD kicks in, but check engine light and a really rough power drop like that could be pretty serious.
Does the CEL stay on? If so have you tried pulling the code yet?
I'd take it to your mechanic ASAP.
traction Control
I havent pulled the code yet but im going to i have a warranty on my powertrain still do you think that should be covered under this? thanks for your reply
mine does the same thing every once in awhile. check engine light comes on but then it goes away once I turn the car off. Annoying as s*** but its only happened twice in over a year.
