HELP !! Tire Fitment
Ok... Well that's wheel fitment. To address your original question, tire fitment is dependent on lots of factors... Do you want stretched tires, meaty tires? How much negative camber are you going to run? What are your suspension specs? Have you or will you roll your fenders? What kind of duties will this tire be seeing?
All things to consider... Basically more info is needed to give you options. Also keep in mind "fitment" is a subjective term. What looks good to some may look like yesterday's garbage to others.
