mrjoshyman
Ok, so today I attempted to put on my winter wheels/tires. This is going to be the first winter with my BC coilovers. i swapped the rear tires without issue, then i swapped the fronts....heres where the trouble came. when i went to move my car i noticed an intense squeal from the front driver side tire...sounded like the rubber part of the tire rubbing against something. i did some investigative work and the sounds is only coming from the front driver side tire, it doesn't appear to be rubbing against the tire well b/c i tested it with the front tire jacked up and it still made that noise. i tried troubleshooting what was causing the noise with no luck. i'm completely perplexed at how this could be happening, especially to only one tire. as far as i know the setup on both front tires is the same...
any ideas what could be rubbing or any reason why id only have a squeal coming from one tire?
