Hi - new to these boards; just got the (soon to be) wife a Mazda 3 earlier this month. Anyway, I'd appreciate some suggestions with a problem I've got.
So she swears that she cleared the ice away... which she probably did, but she didn't lift the arm to break it free. She apparently turned on the wipers and only one moved... The driver's side now moves freely on it's own (if you move it with your hand).
I've looked at it briefly and the first thing I see is that the nut (contained in the black plastic cap) was loose. I took that off and it appears that the bolt that turns the wiper arm rotates properly when the motor is on - it's just turning without the wiper arm. I tried tightening that bolt down by hand, but it didn't do anything.
I think I need to take the arm off and see what's going on there. Does anyone have any suggestions or links to some service documentation that I could look at? Seems like the arm should just lift off that bolt, but it doesn't seem to want to come off too easily - I'd rather have suggestions before I apply any force to it.
I've got some time since a dealership won't be open until like Tuesday so I figured that I may as well have a look to see if it's fixable.
Thanks for your help!
