Help needed with mazda symbol
What it seems to me as far as removing some of the hatch trim, i bet you could probably work the pins out with the badge from the inside... But you have to be more cautious not to break or scratch the trim pieces.
I havent done it personally (mess with the pins) so its just a guess
It doesn't matter. There is still adhesive. The pins are pretty pointless other than allowing you to put the badges back in the OEM placement.
The pins aren't important. The adhesive is.
alright well i know the adhesive will still be there if i heat it up and take it off. so thats all that matters. i just have to heat it upa nd then put it back on.. i dont think theres pins but well have to wait and see. im probably gonna try it all tomorrow. so ill let you know .
Tore small small small pieces of painters tape and used a small pocket knife to wedge them in cracks, took bout hour or two...but headed down for coat 4 now
Well... That's one method... Not exactly the smartest one, but it works. It would've taken you a quarter of that time if you just went and used floss to pull off the emblems.
