Ok, i am in a little need of help tracking down an issue. I am getting trouble codes forst and foremost u0100. But along with this code, i am gettin p0300. I have inspected my intake,hoses,vacuum line visually, found no damage, and rubber all is still pliable. I am at just about 70000 miles
I changed the plugs to ngk dx approx 12000 miles ago, full synthetic every 5000 mi, injen cai, is only mod under the hood. Was running great up until last couple weeks. When im getting on throttle id rarely stumbles, but cruising along at speed limit in any gear, hessitation and misfires. Side note, when i changed my plugs, the drivers side plug was noticably more worn, showing signs of being burned up and greyed. Im just unsure if i possibly should remove the injen cai, replace the maf, replace coil packs, or is it something im missing or something any of you have dealt with?
Any input, suggestons, or experience would be greatly appreciated.
