[Help Needed] Installing the Pioneer Nav Unit
Alpha1
CX-9
Hello gentlemen, it has been a week since I started installing the pioneer Z110BT Nav unit on my Mazda CX-9, however I've reached a point where I'm stuck and need some help.
I've already removed the radio and installed the nav unit in the console.
I have to route the reverse gear wire to the back of the suv either from the passenger side or the driver side.
I decide to go through the driver side, however I haven't been able to take out the dash under the steering wheel.
I also need to route the ipod cable to the glove box. I tried to open the passenger side panel, when I pull, the left side pops off, but the right side doesn't.
EDIT: I found the guide for Mazda CX-7 which works on CX-9 as well, here is the link for anyone who needs it:
(I've only tried opening the glove compartment using this guide, the other parts may or may not work)
http://sites.google.com/site/danmustlearn/CX7radioremovalinstructions.pdf.pdf?
http://w7dps.com/mazda/console_removal.htm
I believe when I ran my Ipod cable to the glove box I just pulled off the trim panel on the right side of the center panel which needed to come off anyway to take out the radio. If I remember correctly that was enough to route the cable to the glove box.
Thanks for the help. I found a guide for Mazda CX-7 which worked on CX-9 as well. I posted the link in the first post.
