i dont know what to do anymore....
this is my final try before i take off the gearbox for full inspection... which will cost lots of $$ here...
problem:
1. when i put in the 3rd gear, sometimes the rev just goes up quicker than usual but the car feel not going anywhere (like not in gear, and i heard grinding sound)
2. sometimes, if i successfully engage the 3rd gear, when i drive on low rpm (2000-3000) on the uphill, the gear shifter will pops back to in-between 3rd and neutral. and my car not moving forward... feel like neutral but not on neutral position...
3. if i dont shift from 4th to 3rd, no problem... but if i upshift, always either pops out or just not in gear properly....
i'm confuse... all i know is:
1. my car is not that powerful to be able to break the gearbox...
2. sometimes it works fine (3 out of 5), the 3rd gear if fine....
3. i never 'flat-shift' (well i tried it 1 or 2 time only
)... always lift my accelerator when i shift
4. i do 'zig-zag' movement from 2nd to 3rd gear, not straight diagonal movement when i up-shift....
help me please.... i want to try to avoid opening my gear box as much as i can....
thanks in advance guys....
problem:
