I'm buying parts online (rockauto) for my planned timing belt job.
I'm thinking of getting:
1. Timing Belt kit
AIRTEX Part # AWK1238 Kit Contains: Water Pump, Timing Belt, Cam Belt Tensioner Pulley, Cam Belt Idler Pulley
2. Valve Cover gasket kit
FEL-PRO Part # VS50574R w/Grommets & Spark plug tube seals; PermaDry molded rubber Gasket
3. Camshaft seal set
FEL-PRO Part # TCS45860 Camshaft Front Seal
4. Crankshaft seal set
FEL-PRO Part # TCS45936 Crankshaft Front Seal Set
5. Aircon - Power Steering belt
DAYCO Part # 5050460DR DriveRite
6. Waterpump - Alternator belt
DAYCO Part # 5040362DR DriveRite
I'll also throw in some coolant and engine oil/oil filter.
Everything should be about $250 ~ $270, inclusive of taxes and shipping.
How much do you think I should get charged for labor?
Do you think there are some unnecessary stuff in there? Or are there other parts that can be replaced during the same time?
FYI, this is for "preventive maintenance." Nothing is broken as of the moment, but I'm approaching 100k miles.
1. Timing Belt kit
