[HELP] Installing JDM DRL LED's with decoders for DRL (non-xenon)
yeah we know it still doesnt work
Verify the ights are not defective wire them using the battery. The resistor should not be needed for testing. The resistor is only used for system monitoring to create a load.
do u have xenon or non xenon model? did u replace ur drl bulbs with leds?
I have xenon head lights and non xenon drl lights. I have not at this time put LED inplace of my OEM DRLs.
yeah that looks like a legit shot for it to work. Give it a try and if it works ill order one too. How much is it?
using the relay harness didn't work. seems like when it is on the DRL mode, it didn't turn on the switch on the relay harness to pass the power from the battery to the LED bulbs.
