So I was mid way through putting in some auxiliary lights in my car that would turn on when the door opened/go off when it is shut, and I accidentally touched the power to the switched ground, which I tapped into from the wiring to the dome light. Now none of it works. The door switches do nothing, the dome light works, but only when switched to ON, not door. The alert in the gauge cluster to tell me a door is open doesn't come on. I tested the switched ground up at the dome light, it is no longer a functioning ground, regardless of door switch position. Checked all the fuses, can't find any that are bad. Obviously this isn't the biggest problem ever, but I'm after some help in whats gone wrong. Did I fry a wire somewhere? Is there a hidden fuse I don't know about? any help is appreciated. It's a 2003 with minimal features, if that matters. crank windows, manual locks, etc.
