help, fuel pres gauge not working!
JCell
BEETEK!
2014 Genesis Coupe R-Spec
i had the gauge for a lil over a year, just never hooked up, i tried today and every thing went good, until i turn the car on and teh gauge doesn't move :(
did i tap into teh right fuel line?
I don't have an answer for your but what are those brackets on top of the valve cover? Are they for putting the plastic cover on the non MSP/MP3 valve cover?
If a return line is what it sounds like it is, I wouldn't think that would be the place to tap.
Ok my quick googling showed that a fuel return line is also known as a "vapor return line" - maybe not in this car, I haven't touched my fuel system so I have no clue. If the line was blocked your fuel pressure would get too high as it is how vapors get returned to the tank, but there wouldn't really be pressure for the gauge to read there if I'm understanding this correctly.
yes, they hold the mp3 valve cover in place.
i read here long ago that i HAD to use the return line :(
well, when i took the sensor off a couple of minutes ago, liquid gas came pouring out, it wan't presurized but the car was off at that time
thanks, i switched it and now it works, 30 psi when runnin, 40 psi at WOT
thanks again guys
Yo WTF here guys? I have mien hookedu p in that same spot, and I thought that WAS the feed line??? I have my gauge just after my FPR (where JCell has his mounted) but it only ever reads like 15psi max. Is the other line the return line or what? I thought the top one was the feed...
