HELP DESPERATE!!! Computer Gurus
it was on, i turned it off, same prob. anyways, i clicked on delete and there were no offline files to delete.
I'm sure it's probably something real simple that we are missing. That's always the case. I read your problem again and you mentioned something about your laptop. Is your laptop on and connected to the network now? Do you share files between the two? If so, try accessing a share on your laptop and open a file. On a side note, do you have to enter a password when accessing the laptop share. If so, this may be causing a time out period before opening your files. When successful in accessing that share and opening a file, try opening a file on your pc and see if that helped. If this does help, your pc seems to be needing something on your laptop to run or is being reference. Possibly a shared printer or fonts or mapped drive. That's pretty much all I can think of now but if anything else comes to mind I will let you know.
on your screen shot it looked like you had a svscan program and another program alg.exe running. try one at a time ending those processes. It sounds like you've got a program running in the background. you also may want to go over to www.zdnet.com and download an anti-spyware program called spybot. Sometimes those spy programs won't show up in the task list. the program's free and does a decent job at picking them up and removing them from the registry and from the program folders list.
hhhmmm.....
Well sounds like a couple things.
1)Anytime you try to access a file, not folder, your anti virus decides to scan it, and check for harmful content. Most antivirus WON'T scan a folder, but files. I would check your av options to make sure its not set up to do that.
2)Since your system runs in safe mode just fine, and when your lan is disconnected than I would bet that when you access a file XP(god I hate it) is trying to search your network for that file, or you do have a process running in the background that is taking up mad system resources.
3)Check to see if you are having any memory issues, I have had a system act the way yours is acting before and it turned out that one of the memory modules was failing...usally memory works or it doesnt...so the person that owned it got new memory I installed it and bam, it worked.
4)I know you formated your hd, but if worse comes to worse write 0's to it. I have had 1 case, infact it was my pc, it was doing the EXACT same thing your's is. I did everything I could think of, format, checked my memory, an updated av, defrag...ect, ect. Nothing fixed it, so I wrote zero's to the drive and started working just fine.
Like protege_speed said, its hard to say what to do cause we arn't sitting in front of the pc. I would just make sure that you arn't running any processes in the background, get ad-ware6.0 at http://www.lavasoftusa.com or get spybot from CNET or TechTv. Scan your system you may find something.
Also, what operating system does your laptop have on it?
laptop is off and disconnected. i also tried getting rid of those two progs you suggested, nothing.
andrew this problem was before the virus thats not it either.
it has to be something to do with the network. forget the laptop i have completely eliminated it from the picture. the computers arent even hooked up to the hub anymore, its just straight from my modem to my computer. as soon as i disable the local area network connection, i dont have the problem anymore.
ok!
Ok, so virus be out of da piture! Still, what OS does your laptop have? Sounds like a funny question bout it would help to know.
edit. just cause your not on the network anymore doesn't mean xp isn't gonna think or look for files on the network. XP does some ****** up s***. So we know its not antivirus, and runs fine in safemode. So you either have a process running in the background, or xp is TRYING to search the network, even when its not on it. Just to let you know, xp doesn't like being networked with non xp os...specially 98!
k.
I am sure you don't want to, but uninstall Kazaa, and run ad-ware 6.0, or spybot. Kazaa is a nesting ground for parasites, trojans, viruses, worms, and overall spyware and crap that is gonna jack your pc.
Also your mail issue....is it on the same system as the one you are having this problem on?
edit. You have a hub? not a router? what brand? how old? Also if its a router what kind of ping times you getting?
its a linksys prolly about 2-3 years old. im not even using it now since the problem. the mail problem seems to be resolved after i bitched out my local isp, suddenly it works (evil)
i just ran the spysweeper prog from cnet, it found 1877 traces and 22 spyware found, one sec lemme see what happens...
sweet
sounds like they were the ones having issues. Just kind of for future reference file sharing software likes to run in the background, along with a lot of other spyware that comes with it and take up mad system resources....
