a lot of the new replies here are about how to get better gas mileage. if you read my post, i get decent city/combined mpg...i am concerned why my 3 100% highway trips avged 22mpg
A few questions/points
1. What were your previous cars and what was their MPG on your highway trips?
2. it's cold out right now.. cold air is more dense. You will certainly get slightly higher mpg when it's warmer out.
3. The CX-5 absolutely hates crosswinds. The car has very advanced aerodynamics that are optimized for still air. Cross winds mess up the flow of air over the car greatly increasing the drag. Other, especially older cars had more simple shapes and are affected down less by crosswinds. If you look at the hood of the CX-5 you'll notice the large ridges on the sides designed to direct airflow around the mirrors. In crosswinds, they won't be doing that and the full surface area of the mirror will be forced to fight against the 80MPH wind.
4. Your car is barely broken in. Your mpg should go up after a few thousand miles when the motor loosens up.
5. gas is cheap right now
6. Do this test.. Get on a level highway on a calm day, set cruise at 65MPH, reset your Average MPG (hold down info button) Drive a few minutes and report back what the average mpg was for that trip. If your car doesn't indicate over 30mpg at 65mph you might have a problem.
