Hello! 2002 Mazda 626 IAC Valve
smalls626
Mazda, 626, 2002
Hello,
My name is Smalls and I am a new user to this forum so let me first start by saying hello, and thank you to my bro for introducing me to the Mazda family.
Ok, well my question is when i drive my car anytime I come to a stop at a light or stop sign. the idle drops below 1000 it comes close to shutting off but has not YET. Though, sometimes after driving my car 7-10 miles after I run into a store and return 15 min later it doesn't turn over at all. I have to turn the ignition all the way to the on position wait for the beeps to stop, then finish turning it and it will crank. It does not do this all the time but quite a bit. Anywho, my brother said the idle problem may be my IAC Valve but I can't find where that is located. Any help would be greatly appreciated. Thank you.
Smalls
You know you need to address some regular maintenance like Fuel injector cleaner and new spark plugs but I've found something else for you to look at.
I'll stop by tomorrow to help you but I found online that the IAC has a connector that almost always falls all or requires a"reseating" after working on the cars timing belt.
