So I changed the fuse for the radio by faking my AC. Fuse and putting it I its place .. now that I put a new 15 amp fuse in in the whole climate controle. Does not work help! It's freezing in Jersey!
check to see if your climate control is getting power and ground, best way is get a wiring diagram. if u have power and ground then u need a new switch
that should help the second one is acutally the first diagram pm me if u need help figuring it out, it would help if u could tell me exactly what happens, when and how and what happens when u use the switch and s*** like that
