take the headlight off. preheat the oven @200 degrees for 15 min. throw the headlight in the oven for 10 min. take out pry the lens off the housing. I used a small screwdriver and knife to cut the glue away as I was prying it apart. take the reflector out. put the headlight back in the oven for 5 min. tke back out press the 2 halves back together and put the headlight back in. make sure to clean the inside of the lens though. you may leave fingerprints in there.
