Installshield 2
Gothenburg Superiority
HC pistons cause a somewhat exponential gain...meaning a bump from 9:1 to 10:1 may come to be around 10whp when properly tuned, everything else being equal...But a bump from 9:1 to 11:1, will be over 20whp...and 12:1 is even more than 30whp...
I don't want to bring this one up too too much, because it is still very early in the build...But I have an FS with aluminum rods and pistons (with right around 12:1 static CR currently) making around 185bhp...only other mod being the J-spec cam set, and tuned off of a Motec...Remember though hp is a funtion of revs...and that output was created at 7500rpm...something I would not recommend with just a set 12:1 pistons...so If I only installed the cams and pistons, i would not have been able to rev as high reliably, thus most likely not reaching that peak...
But any HC upgrades are pretty much worthless when you can't change the engine controller...You will just make a few whp possibly, making it not worth the investment at all...and you could potentially create some large detonation problems...
The octane rating of the gas used is also directly related to tuning...If it is properly tuned you could approach 13:1 CR with 93-94 street gas...but if it is poorly tuned, you could run 104 leaded race gas all day, and still have a grenade...
