ipleadthe5th
- 2003 Mazda Protege5
BlueWolfCry said:I'm connecting the wiring harness to the alpine harness right now. Both have a REM/Turn-on wire (blue/white). Should I connect these? I have a subwoofer that also needs to connect to the REM. Can I cannot all 3 together? Thanks!
Do not connect the Rem from the Apline harness to the incar harness. Connect the Rem wire from the amp to the Rem wire from the harness coming from the Alpine. You can leave the Rem going to the car harness loose.
