Have you seen this air intake?
1Canuck2
http://www.7453217467431.com/produc...ffID=39963&bmUID=1060562596609&bmLocale=en_CA
I found this air intake listed at a Canadian car site. Shipping from the US is ridiculous so adventom.com and others are out. I am wondering if anyone knows anything about it. I haven't heard mention of it any posts here or on some of the other fourms.
Is it the same as the eBay BOMZ intake just rebarnded? The picture does not look like the Bomz, but it could just be a stock intake shot as opposed to the actual Protege intake.
After all the research I have done into intakes, I am no further along on a concrete decision of one over the other. I am loath to spend big bucks on something for the minimal gain it gives, and many posts (and AEM) claim that the short ram gives pretty much the same gain as the cai.
BTW, has anyone noticed how crappily the stock intake is positioned. I was exploring under the hood tonight and the rectangular opening at the top of the engine compartment opens into the small channel where the hood lip rests. I assumed this was open to the grill below, but its not. Can't suck much air through that in a hurry. Plus the larger plastic chamber that the air is initially sucked through is directly over the rad - nice and hot.
Based on these observations, I am more convinced of AEM's claim that the short ram gives the same gains as the cai as the short ram ends up over to the side of the engine and should be able to suck lots of air in (compared to that dinky little stock intake opening). I can't believe that the air is hotter over there than the air that has passed over top of the rad in that plastic chamber. In fact, I would think its fair to say its cooler, which, combined with the reduced resitance of wide mandrel bent tubing, should net roughly the same small gain as a cai. This is based on observation of the layout since I am a bit of a newb to all of this (but understand some basic principles).
Deciphering the claims in many posts does not point one way or another convincingly enough, so saving money for similar gain wins out and I look for the cheaper solution.
Unless you can convince me otherwise...
Robin Smith
I can't get the page to load so I can't tell you. If you have not already checked out the Aero intake at prostreetonline you might want to give that one a look too. Flat_Black has done some testing and the air entering the intake is quite a bit cooler than the engine bay. AND it cost less that the Injen or A&M. Sounds real nice too.
That is the ractive intake. It is a cheap alternative, but apparently you have to go buy a bracket at Home Depot or otherwise to make it fit properly.
I think it's about as good as the ebay intake, but I have never seen either up close.
Thanks for the replies...
I haven't seen the aero intake before (after visiting 3 or 4 boards and searching - weird, is it new?)
It certainly looks neat:Aero Intake
Different than any other design I have seen. So this is a short ram, where does the intake part end up? Over by the hole CAIs use?
In the picture does it show all the parts? I am wondering where the MAF goes? It looks pretty short in general. Any pics of it installed TheLedge? I am very curious about this one. Is that a traditional cone filter in there covered by the nifty carbon like sleeve?
MP54LIFE, when you say custom one do you mean you made it yourself? How? I have pondered buying a U of mandrel bent tubing and doing just that. Any pics of yours? How easy/hard was it? How did you cut the tube?
The intake at the site I listed above is actually branded as a ractive intake. Does anyone have one and can speak from first hand?
It doesn't look like the ractive intake pictured here:
Ractive Intake
This intake looks like the ebay one. Is that what the actual Ractive intake for the Protege 5 looks like?
make your own i have a apexi super intake from japan and i made my bracket. i got it for 40 because the shop did not have the adapter plate. so i made my own the same intake is about 300 if you got it from japan not including shipping
That IS the Ractive SRI for the P5.
I have one and it's the same model number as listed on the Canadian Tire website.
