Have a problem and need help with my DashHawk.
ms6zoomzoom
06 Mazdaspeed 6. Black Mica.
Alright..so today I went to the dealership in the morning to get all the gaskets changed in the engine because of an oil leak I had. Before the dealership, my DH was working fine. Hours later, I pick my car up and when I plugged in my DH, all it said was "Missing codes for PID-"then followed with a couple of numbers like "PID4512," "PID4521", "PID5". I don't know what that means. After scrolling and seeing all those numbers, the screen eventually goes blank with just the light on not saying anything, even when I shut the car off. So I'm not sure if they did anything at the dealership to my ECU, or I have to reset the batt. I've already tried loading my set parameters from my comp to the DH, but that still doesn't work. Can anyone help?
you are running the most recent firmware right? v2.5 i think?
Even if you are, i'd try the "Upgrade" firmware option again, but save your profiles first.
