generix said:done and done. if anyone else needs/wants the link, just PM an email address and i'll send it to there.
Thanks again!
PerfectXtreme said:I've done some hard launches... and had no problems.. other times... I've "attempted" to launch hard.. only having the car go nowhere.. and clutch burn down.... Makes me cry...
Evo's are well known for burning up their clutches early on... All of these sporty 4-cyl turbo AWD cars have clutch issues in one way or another. The only way to solve this really would be to install a clutch you'd see on a 2 ton pickup or something.. but then shifting would be like... a 2 ton pickup...
As best I can tell, depending on how you drive, if you like the speed and power... and zoom around quite a bit, you'll be replacing the clutch in or around 50-60k... You'll meet a lot of people who claim they run the s*** outta their speed6's and have no clutch burning... I met one of these such people down here in cali... went for a ride with him.. he launched twice... smelled his clutch both times... I didn't say anything as I wanted to see if he had an excuse... Apparently he didn't notice....
If baby the clutch, never go above 80... and take 2 min to get there.... this clutch will last you forever... If you do 0-100 in 10 seconds pullin onto a freeway like I do all the damn time... you'll probably be replacing it a bit earlier than other vehicles... However, by the time I need replacing my clutch i'll be able to do it myself =)
rdandy5875 said:Great write-up here: http://forum.***************/index.php?showtopic=59565&st=15
That should bring you to page #2, bt incase it didn't, it's post #16 on page 2, by a member "Super Car Tastes - Skoda Budget", thats his screen name, no kidding.....
He really elaborates. If you want the cliff-nots version:
1.) Loosten the clutch cylinder rod, it has a 12mm locknut, and has a 10mm hex on the rod.
2.)Turn the rod clockwise 3 turns. Re-tighten the 12mm lock nut against the rod coupling.
Why was this link censored?
3.) adjust the clutch pedal stop bolt, so you have about 1/4" freeplay before you feel more resistance.
4.) Test ride. There's a few things you have to test. Does motor start in neutral with clutch out, it shouldn't. Does the cruise contol switch on normally, and switch off when you press down the clutch pedal, it should.
because this site is being retarded.Newf said:why was this censored???
Antoine said:(attn) Please DO NOT post links to other Online Mazda6/MS6 communities.
It is not healthy for the Mazda Forums 6/MS6 community to send our members to other Mazda6 communities. This is a serious problem, especially in new member threads. We must put more effort into developing OUR OWN content and support structure. This is an important rule that allows us to maintain quality and security for our Mazda Forums/MZSPD6.com members.
NOTE: The 6/MS6 Moderator Team will be on the look out for links to other Online Mazda6 communities. They are authorized to edit these links.
Instead of posting links you can...
- Copy and paste information (with credit to the author)
- Post your own original version here of a related topic from another site
- Provide your own answers to member questions instead of linking to answers on another site
- Start GB's here instead of telling members to support another site's GB
I realize some of you are members on other Mazda6 sites and that is fine. I ask that you respect this rule and help preserve our own Mazda Forums 6/MS6 community!
I need everyone's support on this, Thank you!
