Has anyone ever installed this rear view camera?
I bought this off ebay. I have a 2013 CX5 sport. I tried to install it today but as I was trying to put the camera into the license plate hole I noticed the pins that you squeeze on the back of it were refusing to push in all the way. Did I by the wrong size or is there a certain way to make it clip on?
I can’t help, but you may get a better response if you can link to the actual item you bought, with specifications, rather than a picture that shows no identifying features.
@Mrc_z1 did you solve your problem? I bought a different camera but my problem may be compatibility with the screen...
Hola, he probado a sacar 12v del encendedor pero mi problema es que no funciona ninguna de las cámaras. Adjunto un vídeo del resultado.
I have even tried NTSC, Cvbs, Pal camera the result is like the video I share and Ahd, cvi, TVI does not give any image screen remains blue with warning letters nothing more The resolution of the cameras is different from 420tvl to 800tvl and HD cameras but I don't know where the fault is.Generate 6v when you want the unit to power the camera!My intention is to use a device to see both front and rear since the vehicle has a rear OEM camera.
  • VID_20230216_155644.mp4
    45.9 MB
  • VID_20230208_173915.mp4
    10.3 MB
Guy, definitively you need to use an NTSC 6 Volts composite video camera, if you have a 12 Volts camera you need to get a 6v DC --> 12v DC booster converter. Amazon or Aliexpress sell them. I doubt a camera switcher will work but it wont hurt to try after you have one cam working.
