Hand Break and ABS light always on.
bobby777
Just wondering if anyone can answer why these two lights are coming on at the same time?
I checked the break fluid level and it's fine.
(pissed)
I know it sounds stupid, but are you sure the brake lever is all the way down? Just to see if the light is caused by that switch.
When you say its fine, how close to the full mark is it? I had that problem with the light on and it was due to my brake pads being too low. Changed the pads and all was well.
You might have some air in the lines or something is funky with the ABS module... I dont have ABS so Im not too sure why that light would come on.
Has this been on for a while? Does it ever go out? Did something happen before they came on? Any other info you have would be helpful...
Most of the time the lights are on and sometimes there off. I'm sure the hand break is down however your guess at the break pads being low might be right.
Had the same problem, it was an ABS sensor in a rear wheel which was the problem. Replaced it and everything works fine!
I found when my ebrake light was on with the ebrake disengaged, my fluid was low. You could check that. I dont have abs but that might be why the abs light is on too
craig
