Haltech and Closed Loop Control
glyph said:
If the wire has a terminal, you should just slide the terminal into the connector. There should be no grounding involved, as there should be a ground on the connector already. Someone correct me if I'm wrong.
The wire does have a terminal on it to slide into the harness, I just want to make sure the shielding around the wire doesn't need to be connected to a ground. From looking at some wiring diagrams it appears as though it might need to be but I am not 100% clear on it.
I don't quite remember. It's been about a year since I hooked mine up. Best bet would be to contact Juan before proceeding.
I want to do this.
I'm not sure if this will work on my (dos-based) f10. I noticed the manual mentions different versions of the f10. Does anybody with an older model haltech know which version hiboost supplied?
So to reconfirm, i will need the following items and need to do the following:
Items:
--1 x delphi pin, part number 12084912 (or pc terminal?)
--1 x sheilded wire (length?)
--Wideband O2 sensor
Procedures:
1. install the wideband sensor (will it work on the stock hiboost o2 bungs?)
2. run wire from wideband into interior through firewall
3. wire the 5v wire into the haltech via pin #2 (this is a splice job yes? as in, it won't come with a connector to plug into the haltech, right?)
----note: juan's post makes it seem as though you can run the 0-1v wire as long as it's set up in the haltech as 0-1v, or run the 0-5v wire as long as it's set to 0-5v... is that right?
4. Install the gauge (can i / how did you all run the wires to both the gauge and your haltech?)
5. Settings on the haltech:
--1.enable closed loop.
With the wideband working, check the readings, in voltage, in the engine data page. So if you have, lets say 0.7 volts at idle and a 13.7 or so A/F ratio, then set that to 0.7. The same during icruising.
The TPS limit (upper throtle limit) is best at 30%
The lower than I would do 500 rpms
The O2 sensor Threshold voltage must be 600mv
Max fuel increase or decrease can be 10%
Engine cycles at idle 20
--2. Decel cutoff
The setup for the decel cutoff:
Deceleration cutoff parameters: Enable
Decel cutoff: 2000 RPMs
If you want the Overboost fuel cut,
Overboost fuel cut: Enable
Overboost limit: example 800 mbars (11.2 psi)
Overboost restore: example 700 mbars
This will work like a boost limiter as an engine safety device
After all the cahnges are made, please click on "apply".
--3. remove barometric pressure lock
the other question i have is: now i now that there is not "auto-tune feature" but can one data log info from the closed loop operation and turn that into a good tune manually?
I don't think that part number is any good anymore. I searched and searched for it.
Does anyone have different part# ?
That's still the right part number.
Go to http://www.gmpartsdirect.com and search for part number:
12084912
Put it in the box in the top left corner. That gives you the results you need. You can also order them from your local GM dealer.
I'm using closed loop with my stock primary O2 sensor. Haltech reccomends that you do not use your wideband for closed loop, that you use a narrowband instead. I jsut hooked the pink / blue wire from my stock O2 to the O2 input wire and set it up. Works like a charm.
Why is that?
What if the WBO2 has a programable analog out? The Mazda PCM uses mine with no trouble.
Just wondering because yet again my turbo project is on hold due to EMS problems. Looking for something with closed loop and sequential injector control, like a Haltech E8 or Autronic SM4.
