HiBoost TS
jrodhotrod said:Juan,
Is the wire that you are talking about the same one that I already have for the trim knob that didn't work? Just have to attach the 0-1v wire from the AEM to that and it goes into the aus connector on the haltech?
Or can we tap one of the wires in the haltech harness for input so that I don't lose the secondary trim control for fuel?
No Jared, this wire is separate from the trim box wires. In fact you can use the signal from the stock O2 sensor to make it closed loop. Just run a wire from the stock sensor signal wire into pin #2 in the Haltech connector.
BTW, I have the new trim to send it to you. Are you still at the same address?
