HALP! haha just need a quick answer.
krillik
2004 Mazda 3
ok so i installed DDE and i used the method from the independent fog lamps thread shwon here:
(images linked from this :http://www.mazdas247.com/forum/showthread.php?t=123708442 thread)
so my DDE are on always when my ignition is on. but now when i take it out...my fog lamps still dont work.. i didnt do anything else to my car but plug the wire into that small opening. for my DDE.... ?? HALP??
well.. i think i might have blown something. I have aftermarket HID. i accedently hooked up my HID ballast wrong. positive to negative and vice versa bc it was late at night and i was tired, bad move. then i turned on my lights and only the passenger side headlight worked. no foglights so i was like wtf? i checked it and thats when i messed up my HID ballast, so i thought. i just now put in new ones. headlight still doesnt work and neither does fog lights. i think i blew something.. :( but to answer your question, yes my angel eyes work when i turn on my ignition.
I'm at the mazda dealership and she says it wouldn't be a fuse if it was both low beams wouldn't work. Only my driversider lowbeam doesn't work and neither my foglights. Everything else works
Yes everything is good but driverside lowbeam and fogs. And I'm at the mazda dealship and she says wouldn't be fuses bc both lows would be out.
god mazda people are idiots. i was getting a new key programmed and i couldnt find my manual and then the lady was like no its not your fuses because it would make both headlights go out and blh blah blah. the lady told me there was only 1 fusebox in the engine bay so when guys told me about the one uder glovebox i was like what? long story short, it was a fuse and the mazda dealership are idiots.
