Waiting for a software and/electrical engineer to program the factory software to remove the damn lock. I know one of you out there is an EE or CS!
I've messed around a little, but I'm being very cautious as to not brick my device.
how are you getting into it? just snooping on the sd card or did you pull the module and hook it up with the 'usb' port connection thats supposedly on it?
I just installed it an hour ago...its not a traditional usb port bit 2 circular connectors. Possibly the inside and outside of each connector are a channel to be the 4 channels on a usb stick.
There are different ways they may do it.
Software wise, the GPS knows your moving and prevents the system from being programmed. This would only be able to be changed by hacking the software. Chances are the sd card would have a config file with this info on it, maybe encrypted or compiled. Hard to say.
The other method is via the wiring on the back getting a signal when the car is in the drive position. I don't have the nav system to investigate, but you could check it out. If its wiring, it's a simple matter to correct.
If its the software itself, yank the sd card and see if there are files you can read on there. Some may be packages requiring you to open them first, before you can read it.
If I had it, would look forward to hacking it . If its firmware, it's a bit harder....
I am assuming vehicle input as it only locks out at a certain speed. Had it been the GPS, it would lock out only when it reads a certain speed via GPS. So when i don't have GPS signal, it would still lock out.
