H&R Street Coilover users chime in
spdjnke
08.5 CWP Speed3 GT (sold)
KONI yellow and H&R spring combo users chime in..
Hey,
Just wondering if you can share some experiences with this setup, KONI Yellow with H&R lowering springs....what adjustments did you find to work the best in front and Rear??? Also do you recommend going with Adjustable Camber Links in the rear? or is that not necessary.?
Thanks for any info.
I'll let ya know as soon as I get my Koni's. I've heard they're softer (on the softest setting) than stock. And I'm sure on the hardest setting they'll rattle your teeth loose. I expect setting 2 or 3 will firm up the suspension as much as I'd ever want. For the street, at least. And there's a perfect drop all the way around. Though, I'm kinda curious about camber in the rear, too.
come on there has to be some current members running this setup...
maybe you should change the title of the thread from "H&R Street Coilover users chime in" to "KONI yellow and H&R spring combo users chime in"
