H&R Coilover Height Adjustment
Zoom2UCI
I have a set of H&R coilovers set to a 2" drop in the back and 2.5" drop in the front (I think). So right now the back has a bit of wheel gap while the front has none at all. I'm not too sure why I did this in the beginning haha, I think it was cause the body looked pretty even at the time. But now, it looks weird to me so I want to adjust the back so it matches the front. Can someone tell me how I would go about and do this? I have the metal hook tool that came with the coilovers.
I don't have H&R's but i've seen pic's of them, most likely you will need to measure the gap and decide how low you want to go..and then remove the rears to adjust them if you can't get to the adj. collars(perches) with the wrench thats provided. Most coilovers have the adj. collars(perches) on the bottom of the spring seat which would allow easy access..not sure why H&R set theres up the way they did. Heres some pic's in this thread http://www.mazdas247.com/forum/showthread.php?t=123767199&page=3
