so i finally did it and got the car running. this is just to good to be true, the car is a beast! for now i have it set @ 18-20 psi with the ATP fuel cut defender and it works very well. no fuel cuts at all..
i get boost at 3000rpm and full boost comes on at 4500rpm i redline my 18-20psi @ 7k so there is plenty of fun . its pulls so hard that u need to shift so fast as the rpm just revs like its in nutral lol
ill post some races on wednesday and if its nice outside sunday ill go to the track to see my 1\4 mile
to start off you need to disconnect almost everything , take off the batterie, the batterie tray, some hoses, all the original clamps and brackets , all the heat shields next to the turbo! u need 8mm, 10mm, 12mm and 14mm wrench to work on that car and alot more stuff as well. but the main one's are these.
and by the way guys, if you know how to swear in every language that exists then its a good start , u can go ahead and order the kit.
ATP should write (bolt on turbo on pics only not when u get it)
here are some pics of the turbo and my friend installing it lol
its funny as well on one of the plugs there is a tag that says FO.MO.CO is that stands for ford motor company?
