grinding/rubbing after lowering car
03 p5, 92 miata
so everyone, i finally lowered my p5 over this weekend and have an issue pop up right after. Went out for a drive and I can notice this fairly large grinding feel coming through the brake pedal. the feeling is most noticeable then but you can still notice it even when you arent on the brakes. not sure at all what it could be really. wheel bearings were replaced within a year ago and there were no issues of the sort before the strut/spring change. I did notice that I have one frozen caliper (frozen open) and that my front left rotor seems to have a slight gouging in it from something getting on the pad and just cutting away.
any idea what this could be? Im going to look at the car a little bit tomorrow during my lunch break to make sure it is definitely not a bearing. car still needs to be aligned as well after this job
How are your pads? Nothing should be able to get in there and gouge away at the rotor sounds like your brake pads are down to metal
Similar Threads and Articles
